Coupe interior lights
Has thanked: 154 times
Been thanked: 1051 times
Post by scimjim » Mon Dec 05, 2016 11:21 pm
A request has been made on FB for these (I need one too). They have been unobtanium for years - perhaps modern technology has made the manufacture of the covers more viable?
rebel alliance
Been thanked: 69 times
Re: Coupe interior lights
Post by rebel alliance » Tue Dec 06, 2016 12:09 am
If you search (vintage car interior light) on ebay a similar item is on there
Has thanked: 24 times
Been thanked: 105 times
Post by Coupe Racing » Tue Dec 06, 2016 4:32 am
Is 3D printing an option
Post by scimjim » Tue Dec 06, 2016 6:25 am
rebel alliance wrote:If you search (vintage car interior light) on ebay a similar item is on there
Presumably you mean these two NOS? Without measurements they do look similar but I'm looking for a more enduring and controllable supply solution.
Post by scimjim » Tue Dec 06, 2016 6:26 am
Coupe' Racing wrote:Is 3D printing an option
Exactly what I was thinking. Ben Faulkener has suggested it on FB.
Post by toomanysabres » Tue Dec 06, 2016 8:05 am
I made one once (don't laugh) by laying up a single layer of tissue matting on a broom handle. :D
Been thanked: 384 times
Post by peter freeman » Tue Dec 06, 2016 9:13 am
Did you do that just before you flew off Geoff
AllingtonGT
Has thanked: 36 times
Been thanked: 24 times
Post by AllingtonGT » Tue Dec 06, 2016 11:19 am
The ones on eBay: http://www.ebay.co.uk/itm/VINTAGE-CLASS ... SwcLxYMrsk are similar but not the same. I got a pair off a Rover specialist and fitted them to Coupe B pillars but the base is too wide really. The covers are not interchangeable.
Been thanked: 122 times
Post by ScimmyMike » Tue Dec 06, 2016 11:59 am
I've also got a pair of Rover P5 interior lights which are as the ebay advert though didn't pay anywere near that for them, they aren't the same but as the only alternative I came across was a crappy plastic thing from a proper MINI thought they'll have to do, not tried them mind you for sit.
rebel alliance
Post by rebel alliance » Tue Dec 06, 2016 12:05 pm
If you want a lot Jim then try vacuum forming ..Hampshire signs and plastics 02392486633
mn757
Has thanked: 15 times
Been thanked: 11 times
Post by mn757 » Tue Dec 06, 2016 12:19 pm
Not original, but I've fitted a 6a rear loadspace light on mine, it fits nicely on the B pillar and works well
1965 Scimitar GT SE4
1976 Scimitar GTE SE6
1985 SS1 1300 5 Speed
also...
trevor
Post by trevor » Fri Jan 17, 2020 9:53 pm
I have a damaged lense on one of these lights. I can be used, but I could do with a new one - in fact I could do with a second lense as I have another base.
I am going to take a pattern and use it to suction/vacuum mould new ones. I see no problem and if it works I could make as many as I like or get bored.
Watch this place
Trevor S
Post by scimjim » Sat Jan 18, 2020 4:52 am
UPDATE - apparently they’re the same as the Austin Farina range (110 Westminster) without the reflector bit and there are new plans afoot to have the lenses made.
I need one as you can see from this pic.
roymck
Post by roymck » Sat Jan 18, 2020 7:46 am
Better picture showing the inside , also it’s a good idea to change the festoon bulb to a LED to stop burning .
roymck
Post by roymck » Sat Jan 18, 2020 7:51 am
Used Lense on EBay now at £24.99
