Fomoco vacuum advance unit.
Has thanked: 171 times
Been thanked: 158 times
Post by b.c.flat hat » Wed Mar 27, 2013 11:17 am
How do, chaps.
Vacuum advance units for Ford distributors are now 35 years or older and the rubber diaphragms are failing.
Probably costing no more than a few pence when new, there must be hundreds out there on your cars.
Is there sufficient reason for investigating whether they can be repaired and by whom?
Regards, Brian.
MikeT
Has thanked: 21 times
Been thanked: 25 times
Re: Fomoco vacuum advance unit.
Post by MikeT » Wed Mar 27, 2013 1:29 pm
Hi Brian - I've researched these too, as I'm pretty sure mine isn't working as it should.
As I think you've found, the only option at the moment is to convert to a Bosh unit - which I'm keen to avoid, as I've bought a Fomoco electronic ignition.
I'm definitely interested if there's a chance of getting one repaired / replaced.
Mike.
