New replacement for cracked 5a dashes - anyone interested?
Crouchie_b
Has thanked: 111 times
Been thanked: 32 times
Post by Crouchie_b » Sat Nov 17, 2012 6:48 pm
5a dashes seam to suffer from cracking around the fixing holes and the clocks so I've being helping Pete Brown with a mould to make replacements out of fibreglass.
The mould came off the plug that well that all the fine detail such as the crackle finish has come really well.
The final detailing was finished today & 6 coats of willslip wax (wax on, wax off, Mr Miyagi style) applied.
We should be ready to run the first batch pretty soon if any one is interested?
Crouchie_b
Been thanked: 147 times
Re: New replacement for cracked 5a dashes - anyone intereste
Post by Oaksey » Sat Nov 17, 2012 6:59 pm
I might be depending on price
1973 Beige Se5a Overdrive
1969 Se5
1972 Se5a
2005 Honda S2000
2016 BMW 330d
Royal31364
Post by Royal31364 » Sat Nov 17, 2012 7:21 pm
I would definately be interested in at least one
Ian
cookieboy
Post by cookieboy » Sun Nov 18, 2012 2:55 pm
im interested .whats the price including postage please .
Currently scimitarless .
Crouchie_b
Post by Crouchie_b » Sun Nov 18, 2012 6:21 pm
Hi Guys, there isn't a price set as yet, its just a metaphorical toe in the water to see how much interest there is. A with most small batch runs the price comes down with increasing numbers committing to the batch as the development cost is spread over the run.
Black ones will be produced in a black gel coat but not quite sure what to do with the tan ones? it would take some time to ensure a consistant colour match with powder added to the resin, so it may be better to produce them in a ready for paint finish? - coments please.
Crouchie_b
Has thanked: 52 times
Been thanked: 320 times
Post by AJL Electronics » Sun Nov 18, 2012 6:52 pm
I would recommend clear gelcoat and add gelcoat pigment. It is quite cheap to buy a small selection of colours and then a tan could be mixed quite easily. I have a tin of RAL1004 pigment if you should need a little to test.
J55 JGL
Post by J55 JGL » Sun Nov 18, 2012 7:17 pm
Hi Brian
Are you aware that there two different positions for the ignition /steering lock,
Stirred not shaken!
Crouchie_b
Post by Crouchie_b » Sun Nov 18, 2012 7:26 pm
J55 JGL wrote:Hi Brian
Where are the 2 positions and I'll check the mould.
Crouchie_b
J55 JGL
Post by J55 JGL » Sun Nov 18, 2012 7:41 pm
It is about 1inch higher or lower than the one you have Reliant changed them at some point
Stirred not shaken!
Crouchie_b
Post by Crouchie_b » Sun Nov 18, 2012 7:47 pm
J55 JGL wrote:It is about 1inch higher or lower than the one you have Reliant changed them at some point
Typical Reliant
That means that I'll have to measure the location on the one I have and all those interested will have to do like wise to ensure that it will fit.
Crouchie_b
Has thanked: 130 times
Been thanked: 871 times
Post by philhoward » Mon Nov 19, 2012 4:51 am
Fell foul of that one - bought a replacement 5a steering lock which didn't fit mine...
gramshep
Post by gramshep » Wed Nov 21, 2012 9:15 pm
I would be interested too. In black.
Graham Shephard.
1975 SE5A,
MG ZTT,
Velocette Venom, Triumph Speed Triple 1050.
Crouchie_b
Post by Crouchie_b » Sat Nov 24, 2012 7:43 pm
Ok I've had the mould out and measured it and a couple of 5a's today. The early 5a's have the lock barrel centre point 1.25" from the edge of the face of the hexagonal moulding for the steering column while the later ones are 1.75" from the edge.
This does not cause any issue as we have moulds for either and you just need to let me know which one you have.
The RAL colour chart has been ordered and we should be able provide in tan as well as black.
Price yet to be confirmed but an indication of the level of interest will help to set it as keenly as possible.
Many thanks to those who have already expressed interest and for the feedback.
Crouchie_b
SilverComet
Post by SilverComet » Sat Nov 24, 2012 8:43 pm
Interested :)
Ben (1975 SE5a used for wedding). Son of Andy Faulkner (SE6a & Coupe), brother to Daniel Faulkner (SS1 & Equip GT4s), Wonder where I get the reliant bug from...
Has thanked: 188 times
Been thanked: 1272 times
Post by scimjim » Sat Nov 24, 2012 8:44 pm
Why is this in members area tech archive?
