SS1 Vented 223mm Discs
Has thanked: 295 times
Been thanked: 228 times
Re: SS1 Vented 223mm Discs
Post by Corky » Thu Jul 17, 2014 11:37 am
Crouchie_b wrote:
swoakes wrote:Right so basically the GW setup
Yep but without the (cough) £700 price tag :lol:
Or if your budget is a touch more generous you could take less off the OD and fit some bigger calipers too......... and it'd still be an awful lot less than £700, or even £400 if buy the calipers 2nd hand.
scimmy_man
Been thanked: 37 times
Post by scimmy_man » Thu Jul 17, 2014 12:37 pm
or just spend £300 and buy my big brake kit, chevette uprights/hubs new discs an rebuilt callipers.
Crouchie_b
Has thanked: 39 times
Post by Crouchie_b » Thu Jul 17, 2014 1:44 pm
The new ss1 is a fast B road blaster so bigger brakes would be over kill, I've done all that to the SST which wears the willwood set up on the chevette uprights.
All the SST needed was the risk of boiling the brakes with spirited driving which has happened to me before!
This did the job for very little money :lol:
Crouchie_b
Post by Corky » Thu Jul 17, 2014 1:52 pm
You certainly can't argue against your £130 to do the job !
bogstd
Post by bogstd » Wed Jul 30, 2014 9:22 pm
I've been thinking along the lines of vented for my SST and thought they were an easy pickup from the Ebay ads, so this is a wake up call, I'm interested!
wes wilson
Post by wes wilson » Mon Dec 29, 2014 9:57 pm
Crouchie_b wrote:Just to give you a ball park, I've just bought a pair of MG TF vented discs off eBay at £20 each & had them machined to fit by a local engineering firm for £50 the pair. (OD reduced, inner bore enlarged and 4 mounting holes drilled)
That works out at £45 per disc.
Photos to follow once fitted.
what cc engine were the discs for please
scimmy ben
Has thanked: 17 times
Been thanked: 11 times
Post by scimmy ben » Tue Dec 30, 2014 3:49 am
There appear to be 2 different types of vented front discs - 240mm and 304mm. You want the smaller, more common, cheaper ones.
You don't want ones from MGF Trophy or from MGTF 135 or 160.
wes wilson
Post by wes wilson » Tue Dec 30, 2014 5:12 pm
thanq i was checking ebay and found differing results may get a set we have a machine shop in same yard as us so may be a cheap fix with the caliper kit being well priced as well
Crouchie_b
Post by Crouchie_b » Tue Dec 30, 2014 5:25 pm
note of caution- check that the spacers are the same thickness as the increase in the disc thickness between standards & the vented ones you choose!
my first ones weren't (spacer only 12mm & disc 16mm thicker :roll: )
I've given the spacers to Dad (BC Flat Hat) to engineer up some out of thicker plate...which is what we did the first time with the set which are now on Charlotte's Sabre.
Sometimes it appears I've forgotten we did the mod. the right way the first time!
Crouchie_b
scimmy ben
Post by scimmy ben » Sat Apr 04, 2015 6:42 pm
Are these now accepted in Road Going in the Sprint Championship? If so is there now more of an appetite for having a batch made up?
Has thanked: 77 times
Been thanked: 706 times
Post by philhoward » Sat Apr 04, 2015 6:53 pm
During some research for a version 2.0 big disc upgrade I've got as far as a virtually correct disc (1980's Mazda) and a suitable caliper (Saab) given the Carlton/Volvo combo is starting to prove difficult to find.
At this rate it might be easier to go with a set of modified SS1 callipers - except there aren't any discs..
Has thanked: 102 times
Been thanked: 153 times
Post by reliant-reviver » Sat Apr 04, 2015 8:46 pm
Last I heard GW were having 20 pairs made. Could be wrong, but worth a try.
Post by philhoward » Sat Aug 15, 2015 3:49 pm
Looking at them now Graham's stand at Curborough - £50 each.
Post by philhoward » Sat Aug 15, 2015 3:51 pm
scimmy ben
Post by scimmy ben » Sat Aug 15, 2015 4:45 pm
Just the pair? Or have they had another batch made?
