1800Ti Exhaust Manifold
Supersub
Post by Supersub » Sun Sep 24, 2017 3:59 pm
Hi Phil
As I no longer have the SST can you remove me from the list pls.
Many thanks
Mike
Mike Storey
1996 Nissan QX 3.0ltr SEL
2004 Mondeo MKIII 130TDCi Estate
Previous: -1990 SST 1800Ti, 1993 Sabre 1400, 1992 Sabre 1400 (based on 1991 SST), 1996 1.4 K Series Sabre, 1972 SE5a GTE, 1968 SE4b Coupe, 1995 Quantum 1.9ltr 2+2
sub zero
Post by sub zero » Tue Oct 10, 2017 6:33 pm
Hi phil as i purchased mikes SST can you put me down as a possible This is only not a firm order as 1 Been going on for 7 years up to now and who knows how much longer and 2 no idea of the price but i want a spare.
Has thanked: 589 times
Been thanked: 515 times
Post by CNHSS1 » Mon Oct 23, 2017 10:01 pm
There's an original manifold and elbow on ebay now, paul maddison is seller along with few other Ti bits
frase29
Post by frase29 » Thu Feb 15, 2018 1:18 am
Who's currently attached to this project..? As a manufacturing engineering student I'm happy to lend some time (especially after my exams finish in early May) if it might help get the wheels turning! I've also got a little experience with exhaust manifold design, though admittedly tubular welded rather than cast...
'87 SS1 1800ti: LSD, Megasquirt, EBC, Launch Control (oh and a decent stereo ;) )
Been thanked: 164 times
Post by reliant-reviver » Thu Feb 15, 2018 8:38 am
I still have the best intentions to get this sorted... at some point. As time goes by it will become an ever increasing issue, but so far I've not heard of anyone stranded with a car that cannot go back together. A manifold has to be pretty far gone to be beyond salvaging, although I realise it would be preferable for most to spend the money and fit a new replacement that has not been subject to repair.
The route that Chris Eades took is not without it's own issues, and really, I do not think it is viable to have those produced on mass as the supporting modifications required mean that it will not be an appropriate option for many who want a direct fit. To my understanding the patterns are held with the foundry, and they can cast them to order. But it then comes to the machining issues that caused previous headaches. These are issues that were created by some oversight in the patterns produced, not allowing for enough clearance around the fittings, and some difference in the turbo mounting location.
If anyone wishes to further investigate persuing Chris's uprated manifold, I'm happy to hand on what I have and I suspect he can assist also.
Photos for reference -
My view is that the original manifold needs to be reverse engineered. Not altered or modified in any way. Just re-produced in exact standard format and cast in a suitable / higher grade material. Admittedly though I have not made any further inquiries into having this done with a casting company, although there are now plenty on my doorstep what with being in Sheffield! That said, you can't help but look to the far east and the £60-100 manifolds they are producing and thinking "what-if?"
An alternative idea would be having just the port flange section cast, as a singular piece, incorporating the flange and leading abruptly out to two slightly splayed round stubs. Two of these coupled with an off the shelf T2/T25 collector flange, would then allow for bespoke fabrication of a thick wall tubular manifold using "weld elbows" which is a common and straightforward means of fabricating manifolds. Possibility for batch production, slight adaptions for different spec turbos, and actually a very durable end product. However, this brings together the cost of casting and the cost of fabrication time. Although the former is less involved, and the latter is simplified with repeat-ability.
I would also point out that any new manifolds that go into circulation potentially free up a number of secondhand standard units that may be suitable for re-use.
Dcrosby13
Been thanked: 137 times
Post by Dcrosby13 » Tue Jul 24, 2018 2:34 pm
I would be interested also.
I break stuff...... :w
Has thanked: 375 times
Been thanked: 265 times
Post by Corky » Fri Aug 23, 2019 10:21 am
Are there any of these manifolds sat on a shelf anywhere? Drilled or un-drilled?
I’d be interested in purchasing it if one exists.
I see from FB that Chris actually has one fitted to his Sabre.
Has thanked: 129 times
Been thanked: 870 times
Post by philhoward » Fri Aug 23, 2019 10:24 am
I think that was the prototype? Chris was/is involved heavily with it.
Dcrosby13
Post by Dcrosby13 » Fri Aug 23, 2019 10:27 am
I'm sure if you sweet talk dad he would make you a log out of stainless
Post by Corky » Fri Aug 23, 2019 11:00 am
I’d be happy to pay Steve to make me one. I have the SS flange already. I was thinking of buying a cheapo s13 manifold and trying to join the two together.
Post by reliant-reviver » Fri Aug 23, 2019 11:03 am
Talk to Chris. It's all back in his hands now.
My understanding is the patterns are still with the foundry and you could have one made to order.
Mark Wilson offered to take a look at the machining when I was investigating having more made. My feelings were that it could largely be corrected at this stage rather than re-working the patterns. However, you would need to do additional work (new downpipe etc.) to suit but that's well within your scope I should think.
MadMax
Been thanked: 8 times
Post by MadMax » Wed Jul 01, 2020 8:04 pm
Hello everyone
I have been working hard to replicate the Nissan CA18ET turbo manifolds which seem to be in demand. I've tooled up and produced a couple of prototypes, they are fully TIG welded and constructed from tubular pipe/bends with thick mild steel flanges to prevent any warpage.
They are designed to keep the turbo in the standard location, avoiding the dizzy, charge pipe, heater hoses and with good access to the fixings. The manifold is entirely hand made, and as such takes quite some time. Nevertheless I am hoping to produce several of these for our Nissan powered small sports enthusiasts.
The one I am currently working on should be ready for testing soon. I see a lot of people were interested in a reproduction of the original cast manifold, so if this tubular version appeals then please let me know.
Any questions/constructive criticism welcome. Hopefully the photos load alright...
Bends
Flanges
Collector1
Collector2
Prototype manifold
Max Benton
Reading, Berks
'Zeus' - Yellow SE5a
Post by Corky » Wed Jul 01, 2020 8:13 pm
Nice work Max. Any idea about price?
Post by CNHSS1 » Wed Jul 01, 2020 8:15 pm
Noice!! 8)
Post by philhoward » Wed Jul 01, 2020 8:48 pm
Almost makes me want to buy a Ti..
Almost, I said :mrgreen:
