Astonished
Been thanked: 371 times
Astonished
Post by peter freeman » Thu Sep 26, 2019 10:39 am
Over the years I have bought various kinds of alloy wheel cleaners most of which left the alloy dull. Today I thought I would try something different so used Astonish oven cleaner - used the sponge part of the applicator not the abrasive side and its done the job and seems to have left the shine on the alloy. I would not advise it for painted or lacquered wheels though. I would be interested to hear if others find it as suitable as I have and at a fraction of the wheel cleaner price.
Has thanked: 32 times
Been thanked: 49 times
Astonished
Post by Alan SS1 » Thu Sep 26, 2019 1:04 pm
i used 'pickling' fluid from paper-mill, used prior to welding SS pipes, had to use with care as it was 'phosphoric/nitric acid mix :shock:
EDIT
use with caution/ at your own risk etc :w
drcdb15
Has thanked: 30 times
Been thanked: 29 times
Astonished
Post by drcdb15 » Sun Oct 13, 2019 4:49 pm
As Alan said, use at your own risk! Not quite sure what sort of alloys you are using it on, since you advise not using it for painted or lacquered wheels - because pretty much *all* alloys *are* painted or lacquered, to maintain their shiny surface. If you are cleaning up alloys that have been stood in a barn for 50 years then as a stage in the etching and cleaning process I imagine the oven cleaner can be fairly good at removing oxide film and other age-related corrosion or general grot, but as a cleaner for basically OK normal modern alloys I think there'd be a good risk that continued use would be similar to paint stripper...
Chris
Astonished
Post by peter freeman » Sun Oct 13, 2019 5:21 pm
Wolfs not painted or lacquered - and the rims of my MB wheels which are also not painted or lacquered
