Floor Drain holes
Rev Light
Been thanked: 30 times
Floor Drain holes
Post by Rev Light » Wed May 08, 2019 1:38 pm
I have some holes in the floor of my SE5A. Are there supposes to be some grommets or summat in them??
SE5a 'Fancier'
Been thanked: 385 times
Floor Drain holes
Post by peter freeman » Wed May 08, 2019 1:41 pm
Grommets will lead to wet feet if your car leaks - they will lead to wet feet if it does not leak but you travel through fords. Some you win - - -
Been thanked: 559 times
Floor Drain holes
Post by Roger Pennington » Wed May 08, 2019 1:50 pm
The mk3 Cortina I had years ago had some grommets in the boot floor with a hole with a 90deg bend in it, so they would drain out, but were less likely to let water in :)
Rev Light
Floor Drain holes
Post by Rev Light » Wed May 08, 2019 3:41 pm
Fortunately my car no longer leaks....much. I don't have any carpet either - long since rotted away. I wonder if I can make them whistle?
SE5a 'Fancier'
td99
Has thanked: 17 times
Been thanked: 33 times
Floor Drain holes
Post by td99 » Wed May 08, 2019 4:06 pm
:) :) You had me laughing there Peter! I hear the voice of experience....
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Floor Drain holes
Post by peter freeman » Wed May 08, 2019 4:08 pm
On a run ( scimitar ) the lead car took us through a ford - you learn one way or another
