Steering
ColinRichards
Steering
Post by ColinRichards » Thu Apr 20, 2017 3:52 pm
Does anybody know if you can get a quick steering rack for a SE5?
Been thanked: 380 times
Re: Steering
Post by peter freeman » Thu Apr 20, 2017 4:34 pm
Quicker if you fit EPAS.
Has thanked: 153 times
Been thanked: 1038 times
Re: Steering
Post by scimjim » Thu Apr 20, 2017 4:45 pm
welcome :-)
I've never heard of a quick rack - Mark (gtcse8) is the man to ask, or John Louch (who competes a GTE)
Is it for competition, or an attempt to lighten the steering?
Has thanked: 73 times
Been thanked: 682 times
Re: Steering
Post by philhoward » Thu Apr 20, 2017 4:50 pm
A quick rack would have the opposite effect?
Re: Steering
Post by scimjim » Thu Apr 20, 2017 4:55 pm
exactly :-)
MarkHawkins
Re: Steering
Post by MarkHawkins » Thu Apr 20, 2017 5:38 pm
I've heard of a heavily modified 6a being fitted with a PAS rack without the PAS to make turning the wheels quicker on the track.
Custodian of :
1968 '4b Coupe HBL 725G
ex 1974 '5a auto - VLN 826M
ColinRichards
Re: Steering
Post by ColinRichards » Fri Apr 21, 2017 6:52 am
It is for track use to reduce the number of turns lock to lock.
I will have a look at the 6a rack to see if the number of turns lock to lock is less.
They are dead easy to pick up for Fords so I was hoping the rack from the 5 might be the same as a Ford, doesn't look like it though.
Re: Steering
Post by scimjim » Fri Apr 21, 2017 8:15 am
6a rack won't fit a 5.
Re: Steering
Post by philhoward » Fri Apr 21, 2017 8:58 am
I'd be having a chat with Mark Wilson (gtcse8 on here) - what he doesn't know about these racks isn't worth knowing. If you can fit a quick rack to one, he'll know how and be able to do it pretty reasonably too.
Been thanked: 61 times
Re: Steering
Post by Nick » Fri Apr 21, 2017 10:31 am
Be very careful with changing the rack as it is very easy to get serious bump steer. The compie boys are the ones to talk to. Trevor Short has one is his Coupe.
Has thanked: 415 times
Been thanked: 350 times
Re: Steering
Post by CNHSS1 » Fri Apr 21, 2017 10:45 am
Trevor had his from Iain Daniels Motorsport in Appleby Magna, Leics
GavinR
Been thanked: 20 times
Re: Steering
Post by GavinR » Fri Apr 21, 2017 8:31 pm
I think Iain Daniels fits converted TR6 quick racks, when I looked into it a few years ago
I've got a quick rack on mine, made using the standard rack and a pinion with more teeth from a different quick rack, and some machining as the angle was slightly different.
This gave 2.4 turns lock to lock and helps a lot on tight corners
Gavin
GavinR
RSSOC Member 3513
1971 SE5a
1970 SE5 Project
Has thanked: 34 times
Been thanked: 157 times
Re: Steering
Post by gtcse8 » Sat Apr 22, 2017 11:18 am
The SE5 rack is already Quick with 3.5 turns lock to lock, or slightly different if the Trunnion stops have been removed, but the Trunnion bolt may rub on the discs.
I do have a few Specials that are 4.25 or 4.5 turns that will make the steering much lighter.
These are a direct replacement and just have different internals fitted.
EX SST 1800Ti
1969SE5
Steering
Post by 1969SE5 » Fri Dec 08, 2017 7:23 pm
hi chaps, anyone had experience of fitting rack stops ? my trunnions touch the inner brake disc face on full lock, rebuilding the trunnions and have bought a kit with rack stops provided. any advice appreciated. cheers :roll:
Steering
Post by scimjim » Fri Dec 08, 2017 7:50 pm
do you mean the original type with eccentric stops? If so, loosen the attachment bolt (20) and rotate the stop (19) until it restricts the movement adequately.
se6 front suspen 3.png (277.54 KiB) Viewed 2252 times
