Diff pinion oil seal
Been thanked: 52 times
Post by Old and Slow » Mon Nov 16, 2015 4:37 pm
Can anyone recommend a source for the pinion oil seal - I think the Sabre Six is fitted with a 7HA diff (ignoring the axle shaft fixings etc, how can I tell whether the diff is a 7HA and not 5HA?)
Philip
Has thanked: 64 times
Been thanked: 630 times
Re: Diff pinion oil seal
Post by philhoward » Mon Nov 16, 2015 5:52 pm
Picture of the backplate will probably confirm..
Either way, probably easiest to speak to Nigel at QRG?
Has thanked: 22 times
Been thanked: 131 times
Post by gtcse8 » Mon Nov 16, 2015 6:47 pm
Hi Philip
I keep most oil seals in stock, do I take it you need a seal for a Straight 6 7HA ?.
It don`t say that in the subject heading?
Post by toomanysabres » Mon Nov 16, 2015 7:56 pm
Old and Slow wrote:Can anyone recommend a source for the pinion oil seal - I think the Sabre Six is fitted with a 7HA diff (ignoring the axle shaft fixings etc, how can I tell whether the diff is a 7HA and not 5HA?)
Philip
I think you mean 4HA not 5HA? 5HA never used on our Reliants to my knowledge and unless its been changed your Sabre Six will have a 7HA.
Anyway
Easy way to tell – there are 2 bolts either side of the centre line on each side (4) fixing the axle cover. On a 7HA these are about 18.5 cm apart and on a 4HA about 22 cm.
I am pretty sure QRG have the 7HA ones. (hopeso as my Sabre 4 is leaking)
Post by Old and Slow » Tue Nov 17, 2015 4:55 pm
Thanks for all the feedback: excuse my fat fingers, the "4" on my keyboard is next to the "5" for some reason!
Next step - get underneath again, with the tape measure, thanks for the very useful info.
Lastly, yes it is a straight six, Mark, but I'll measure the diff first, just to be on the safe side, and then get back to you.
Philip
Post by Old and Slow » Wed Nov 18, 2015 3:27 pm
The distance between bolt heads is approx 19cm, certainly not as wide as 22cm, so it's safe to say it is a 7HA; I'll follow up with Mark to get a new seal. Thanks everyone for helping.
Philip
heathsabre
Post by heathsabre » Tue Nov 07, 2017 3:38 pm
Hi Philip
Did you resolve this issue? I now have a leaking pinion oil seal on our “ new” Sabre. I’ll try QRG for the seal.
Tony & Jaki Heath
RSSOC Sabre Registrars
1964 Sabre Six GT
1963 Sabre Six convertible
Post by Old and Slow » Fri Nov 10, 2017 5:34 pm
Hi Tony,
Yes, I put a new seal in, but had to destroy the old one whilst removing it.
Here's a picture of it:
new oil seal
(picture title is wrong - this is the old seal)
It came from Autospin 0121 4721243 sales@autospin.co.uk I spoke to Debby; Part No. 28713762-d3 the size is OD 2.875", ID 1.375", Thick 0.625"
I also found a picture of the seal on the oilsealuk.co.uk website, I believe they can still make leather-based seals if that's what you want.
Good luck.
Post by Old and Slow » Sat Nov 11, 2017 11:23 am
Hi Tony,
I thought I'd look through my files for the receipt for the seal, but it looks like I eventually bought it from QRG as they are the only receipts I can find.
They sent me Part No. 207782R which apparently is for the early type and it didn't fit.
The replacement part was 202463 which must have been the one I used.
Sorry for the confusion, I thought I'd kept meticulous records but it seems not.
Hope this helps.
chrisgallacher
Post by chrisgallacher » Sat Nov 11, 2017 11:43 am
Was your new seal a leather or modern rubberised one Philip?
I last did this job on the Sabre several years ago and used a leather one and it seals OK, but there must be modern ones available now. Just wondered.
Chris Gallacher
RSSOC Rally Secretary
rally.secretary@rssoc.co.uk
Post by Old and Slow » Sat Nov 11, 2017 1:41 pm
Hi Chris,
If I remember correctly, I'm sure I soaked the seal before installing, so it must have been a leather one.
Perhaps checking with QRG what they can supply will confirm.
As implied above, I must start keeping better records! :?
