Temp senders
Been thanked: 840 times
Temp senders
Post by scimjim » Sun Apr 05, 2015 8:32 am
Saw this on retro-rides and thought it may prove useful to somebody
all are 1/8 NPT fitting unless otherwise stated.
Black (screw fitting) - 52610
@25° = 195 Ohms
@100° = 20 Ohms
White (screw fitting) – 52750 – listed for a Escort TC, Mk.2 Cortina TC.
@25° = 250 Ohms
@100° = 22 Ohms
Green (spade fitting) – 52700 - listed for a Morris Minor, Vitesse, Herald, Magnette, Austin A30, A40, Husky etc.
@25° = 300 Ohms
@100° = 14 Ohms
larger 5/8” thread size.
Black (screw fitting) - 53170
@25° = 358 Ohms
@100° = 55 Ohms
Red (spade fitting) – 52710 - early Anglia
@25° = 650 Ohms
@100° = 43 Ohms
Black (spade fitting) –52630 - late Anglia
@25° = 662 Ohms
@100° = 58 Ohms
Intermotor sender part numbers and specs
Yellow (screw fitting) - 52620
@25° = 775 Ohms
@100° = 23 Ohms
52910
@25° = 780 Ohms
@100° = 37 Ohms
White (spade fitting) - 52740
@25° = 1005 Ohms
@100° = 64 Ohms
Voilet (spade fitting) - 52600
@25° = 2000 Ohms
@100° = 41 Ohms
Violet (screw fitting, supersedes red screw fitting) - 52640
@25° = not available
@100° = 51 Ohms
Re: Temp senders
Post by Roger Pennington » Sun Apr 05, 2015 12:18 pm
Stickied for reference :)
ALSE6
Re: Temp senders
Post by ALSE6 » Mon Jan 11, 2016 6:04 pm
Very interesting. I spent many an hour (and internet searches) looking for the correct sender for my 1971 Zodiac MK4 Executive (the water pump, rad, engine etc were in good order). Trying out various senders always gave me HOT temp (near or in the red) reading on the temp gauge, and that with the water temp in the rad being about 90C. Even our MK4 club was not able to fathom out my problem! However, I was given to be-leave that the sender has to match the temp gauge. So I ended up with a White Spade Fitting. Now with the car at working temp the temp gauge reads just above the blue. The ohm readings in the above listing are close to what I have gotten. Engine cold = 1500 Ohms, Engine working temp = 106 Ohms. As for my 1976 SE6, I have yet to check it out. Yep,+1, stickied for reference . Cheers ...> Alan
1976 SE6 GTE. 1976 SE6a GTE. 1971 MGB-GT. 1972 TR6. 1971 Ford Zodiac MK4 Executive
