essex core plug
jond
essex core plug
Post by jond » Wed Apr 04, 2012 2:08 pm
how many core plugs are fitted to an essex engine,ive got a kit with 12 the same size plus 2 larger diameter,on my car ive found 2 below the manifolds each side plus 1 each side at the back of the heads do they send some spare in each kit,plus how are they fitted i was going to use a socket thet fits inside the lip of the core plug and tap it in with that,does that sound ok
Been thanked: 539 times
Re: essex core plug
Post by philhoward » Wed Apr 04, 2012 2:14 pm
From memory:
2 on each head
2 on each side of the block
a few (!) behind the flywheel (one large for water, other for camshaft from memory)
Think there's 2 or 3 at the front of the engine behind the timing cover backplate as well?
Has thanked: 59 times
Been thanked: 86 times
Re: essex core plug
Post by b.c.flat hat » Wed Apr 04, 2012 3:38 pm
How do!
I've just bought a Ford packeged kit from Burtons which has 1 at 2" dia, 1 at 1 5/8" dia and 12 at 1 1/4"dia.
Clean the holes in the castings to remove rust, find a socket or similar that fits inside the cup side of the core plug, use some good quality gasket goo around the edge and radiused corner, tap them in until they are just flush with the casting. Make sure they go in perpendicular, aligned with the hole axis.
Regards Brian.
Re: essex core plug
Post by scimjim » Wed Apr 04, 2012 6:36 pm
This may help?
3 on the front
5 on the back - the large one is the end of the cam (be careful removing)
and two on the side (other side identical)
jond
Re: essex core plug
Post by jond » Wed Apr 04, 2012 11:24 pm
thanks very much,i wont be fitting the larger ones as i hopefully dont need to remove the gearbox(famouse last words) ill wait till it needs a clutch then change em
I did manage to fit the ones on the side of the engine apart from the one behind the starter today plus the 2 at the back of the cylinder heads,nice and easy to do as the body is now 10 inches above the chassis i also used the sealant as suggested so hopefully no future leaks,thanks for that top tip,now ive got a few days free over easter so ill be under the car painting the chassis ,also trying to get my mate to do the small repairs that the chassis needs as he is a welder by trade
Re: essex core plug
Post by Scimher » Wed Apr 04, 2012 11:53 pm
Hope it all goes well....!!!
tony.idle
Been thanked: 55 times
Re: essex core plug
Post by tony.idle » Thu Apr 05, 2012 12:21 am
There's no point in changing blanking plugs (as opposed to core plugs) because they don't corrode. However I'm not sure how many there are or the position of them other than the obvious one that closes the camshaft tunnel.
Tony
RSSOC 2332 since 1981
Autofive
Re: essex core plug
Post by Autofive » Thu Apr 05, 2012 1:05 am
in my experience its usually the largest one that rots out first, well worth changing if you have the plug
Spartacus
Re: essex core plug
Post by Spartacus » Sun Sep 16, 2012 10:51 pm
In my experience, the ones at the back of the engine only start to leak just after you've fitted a new clutch....
SE50039
Re: essex core plug
Post by SE50039 » Wed Jun 05, 2013 8:43 am
Jim, if you need to be careful removing the cam plug at the back, what is the recommended procedure? I have a weeping, damaged one! Thanks, Geoff.
1968 Reliant Scimitar SE5
1973 Ford Granada 3.0
1962 Ford Zephyr Raymond Mays
Re: essex core plug
Post by scimjim » Wed Jun 05, 2013 8:53 am
Ideally you would use a broom handle from inside (cam removed)
If you need to do it from the outside, the plug won't rotate as it abuts the rear cam bearing, so I think you'll either have to try and pull it out (self tappers) or simply seal it with JB weld or similar (which I think I would do unless the engine is out)?
SE50039
Re: essex core plug
Post by SE50039 » Wed Jun 05, 2013 9:01 am
First option is out of the question as my mother-in-law needs her transportation........
Engine is out of the car so it's a little easier. Is it a conventional core plug, i.e. not threaded? Thanks again.
Re: essex core plug
Post by philhoward » Wed Jun 05, 2013 9:06 am
I'm not aware of any threaded core plugs on the Essex (there are threaded plugs but they are used to seal oilway drillings - and there a few of them which rarely get removed to clean the oilways; Coupe Racing has mentioned them several times in the past). They are a (very) tight push fit.
Been thanked: 87 times
Re: essex core plug
Post by Coupe Racing » Wed Jun 05, 2013 9:50 am
philhoward wrote:I'm not aware of any threaded core plugs on the Essex (there are threaded plugs but they are used to seal oilway drillings - and there a few of them which rarely get removed to clean the oilways; Coupe Racing has mentioned them several times in the past). They are a (very) tight push fit.
Just to clarify , the very small plugs that have a recessed hex in them are threaded and not a push fit.
All waterways core plugs are interference (crush) fit and can be tight
I always paint the rear of all my core plugs to help prolong their life
I don't feel it's necessary to replace the cam gallery plug unless it's externally corroded and then the worst you will get is an oil leak
SE50039
Re: essex core plug
Post by SE50039 » Wed Jun 05, 2013 10:50 am
It looks like the cam plug has had an attempt to remove it, unsuccessfully, and it's suffering due to this. While the engine is on the floor it makes sense to replace it properly, have you ever removed one externally Coupe Racing? Cheers.
